Need help with getting my flysky tansmitter to talk to the quad
Kellbolone1234
Ok so I built my first quad n connected to betaflights newest version. Everything on the quad works fine. I binded the qaud to my flysky fs-i6 transmitter and it binded fine. I go onto betaflights and go to ports select ppm and still can't get it to connect. I've watched endless YouTube videos but they r older videos and the betaflights software has been updated since then. I'm a complete noob im just getting into this hobby and I need as much help as I can get. I've been trying to get it to connect for about 2 weeks n at a few points I was like screw this I quit I don't want to do this **** anymore. But I always end up going right back to it and trying to figure it out. I'd appreciate any help I can get. I know this is probably a dumb question to most of u lol but I am clueless when it comes to this kind of stuff.
Reactions: NeoCloneOne
Ppm uses a 4 wire hook-up, are you sure you are using ppm?
Seems you are hooked up sbus, or ibus.
The FC says sbus/ppm where I soldered the receiver to. I'm not sure what im doing wrong I followed all the steps on the "$100 build" on YouTube by uav futures and it won't work. Could it be that my computer is to old to work with betaflight?
Have you gotten it to connect to betaflight configurator? Your computer can't be too old.
Welcome to DRP forum @Kellbolone1234!
Don't give up, you are almost there, and you will need determination when you start learning to fly.
Did a quick google search, looks like FlySky FS-i6 supports iBus (essentially the same as sBus, a serial protocol with 1 wire), have you tried setting up BF for iBus or sBus to see if it will work?
Please take a close picture of the Rx connection and the FC . Also, take a screenshot of the BF screens that you configured the RX
Sent from my iPhone using Tapatalk
I built the same quad. The receiver uses power and common from 5v pads on the pdb. The other wire gets soldered to the proper one on the plug from the flight controller. The 3rd wire it is white. The 7th wire is white but that is for led. The plug on the FC is plugged into Io1 port.
My ppm is plugged in on the right of the arrow not the left
Here is my quad using the same board, I am sBus but your iBus should be the exact same I believe. I only use power/ground/signal (on the white wire for me) and the yellow one is the Smart Port which gives me telemetry back to my RC. As you can see it is on IO_2 using 1 white wire to give me my control over the quad.
I would think you would want to use the iBus instead of PPM or PWM, much faster and simpler.
Sounds like you are having the similar problem I had when I first got started on racing quads. I've watched that $99 build by Stu at UAV Futures about a hundred times on YouTube - That's the bug that bit me to get into the hobby! It sounds like you're really close and learned most about droning from YouTube University as I did.
The problem I was having, was that I got a Floureon 250 racer and it worked very nicely out of the box. It also uses the FlySky transmitter/ receiver combo. What happened first was that I updated the firmware to the latest version, then immediately after that, the quad wouldn't respond to the transmitter sticks. I started flashing different versions of firmware with Cleanflight (very similar to Betaflight) and noticed the later versions would not allow the quad to work. They will allow me to bind to the receiver, but not allow me to arm the motors at all. Then I checked in the Receiver portion of Cleanflight, it wasn't showing any responses to stick or switch movements on any channel. Found out I had to switch it to PWM protocol. I did that and I could finally see the channels responding properly. Then I would bind to the receiver again, and still not arm. I tried it for a few nights with no success. So what I did was downgrade the firmware on the FC to a lower version, and the quad responded again. For whatever reasons, the FC would bind but not respond to the transmitter is beyond me.
Check if your receiver responds to transmitter stick movements on Receiver section of Betaflight. Switch FC to PWM protocol if needed. If it still binds to receiver, when you try to arm motors, check if a red LED blinks when you do stick movements. If it does and the quad still doesn't arm, you will have to downgrade firmware to a lower level as I did. Looks like you are using the NAZE32/ 10DOF F3 spracing FC. I have that on my Eachine 250 racer and had the same problem. I did the same thing (downloading firmware level) and now both quads are working fine.
@NeoCloneOne,
Great of you to jump in and try to help, it is what makes this forum great, that we all try to help each other!
Regards
Randy (HTP)
Glad to help when I can. I'm a full time digital field tech specialist, so I do troubleshooting all the time. So naturally, I have a passion of trying to solve technical problems. I'm no coder, so I have a hard time with softwares, but I try.
Hey everyone,
I have the exact same problem. I have flashed all versions off spracingf3 and it still doesn't work! I have also configured the receiver to ibus, sbus, serial-based receiver, ppm pwm, and pretty much all of them! I have been watching countless videos on how to fix this but I still can't figure it out. I can bind my flysky i6 transmitter and my fs ia6 receiver but in the receiver tab on betaflight, it doesn't show any stick movement.
Please do help,
Sid
Welcome Sid @sidtiwari2609, happy to have you here!
Don't "try everything", that is never the answer in this hobby, research what your gear is capable of and then configure for that one thing and keep working it till you get success. Plugging into the PC and connecting with BetaFlight Configurator can be a hurdle, but you are past that. Second big issue many run into is getting the FC to see the receiver properly so when you move the sticks it responds. I am not the Flysky expert but I think from GreenOrange's post earlier that the receiver you have is PPM capable but not iBus capable.
I think you should be aiming for PPM receiver protocol so let's look at that. You will want to make sure that NO Ports are set for Serial RX, they should all have Serial RX turned off. You will want the Configuration tab Receiver section to have the "PPM RX input" set. Don't forget to save and reboot
You will want the PPM pin from the RX to be wired to IO_1 connector, pin 3.
Make sure props are off and plug to the PC and you may even have to plug the battery up to the quad so make sure your vTX antenna is attached properly.
If that still doesn't work can you get a decent picture of your receiver wires connected to the FC or a diagram of what you have connected?
I think you should flash the latest Betaflight onto the FC, rev 3.5.1 should be fine and I would leave that and not mess with that again. That will make it easiest to help you figure this out.
Soso
