Quad Will Not Arm - Issue Resolved
SpeedBump
Hi,
Not sure what’s happening, but after installing a new Receiver on my quad, the quad will arm in BetaFlight, but it will not arm when I turn on the arming switch.
mice not changed any settings in BetaFlight other than those related to the receiver and the controller. The Controller has full communication with the receiver. All my stock movements work and move accordingLu as seen in BetaFlight. The motors will arm and spin within BetaFlight
Any suggestions as to what’s causing the quad not to arm is appreciated.
Try doing a "status" command in the CLI tab to see what the Arming Disable Flags are.
Hi,
Thanks for your reply and recommendation. I ended up flashing BetaFlight 4.1.7 and that seem to fix it.
I purchased this quad from someone that had a DSM receiver and he must have set something that was causing the issue with the receiver that I installed.
Cheers,
Sam
Eleveniseven
