Here is the Diff all CLI and screenshots of the mode tab.
# Diff all
# version
# Betaflight / STM32F411 (S411) 4.1.4 Feb 4 2020 / 17:26:13 (bc9715eec) MSP API: 1.42
# manufacturer_id: MTKS board_name: MATEKF411RX custom defaults: YES
# start the command batch
batch start
# reset configuration to default settings
defaults nosave
board_name MATEKF411RX
manufacturer_id MTKS
mcu_id 004800193437510335313736
signature
# name: AVELLA_THS1
# feature
feature -AIRMODE
feature -RX_SPI
feature RX_SERIAL
feature TELEMETRY
# beeper
beeper -GYRO_CALIBRATED
beeper -RX_LOST
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
beeper -CRASH_FLIP
beeper -CAM_CONNECTION_OPEN
beeper -CAM_CONNECTION_CLOSE
beeper -RC_SMOOTHING_INIT_FAIL
# beacon
beacon RX_LOST
beacon RX_SET
# serial
serial 0 64 115200 57600 0 115200
serial 1 8192 115200 57600 0 115200
# aux
aux 0 0 0 1600 2100 0 0
aux 1 1 1 1700 2100 0 0
aux 2 2 1 1300 1700 0 0
aux 3 13 2 1400 2100 0 0
aux 4 28 3 1400 2100 0 0
aux 5 36 4 1300 2100 0 0
# rxrange
rxrange 0 988 2011
rxrange 1 988 2011
rxrange 2 988 2011
rxrange 3 988 2011
# vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable band 1 BOSCAM_A A CUSTOM
5865 5845 5825 5805 5785 5765 5745 5725
vtxtable band 2 BOSCAM_B B CUSTOM
5733 5752 5771 5790 5809 5828 5847 5866
vtxtable band 3 BOSCAM_E E CUSTOM 5705 5685 5665 0 5885 5905 0 0
vtxtable band 4 FATSHARK F CUSTOM
5740 5760 5780 5800 5820 5840 5860 5880
vtxtable band 5 RACEBAND R CUSTOM
5658 5695 5732 5769 5806 5843 5880 5917
vtxtable powerlevels 5
vtxtable powervalues 25 100 200 400 600
vtxtable powerlabels 25 50 100 200 400
# master
set gyro_lowpass2_hz = 0
set gyro_calib_noise_limit = 100
set dyn_notch_width_percent = 9
set dyn_notch_q = 250
set dyn_lpf_gyro_min_hz = 160
set dyn_lpf_gyro_max_hz = 260
set acc_trim_pitch = -28
set acc_trim_roll = 14
set acc_calibration = -188,-57,-157
set mag_hardware = NONE
set baro_hardware = NONE
set min_check = 1010
set max_check = 1990
set rssi_channel = 12
set rssi_offset = 20
set serialrx_provider = SBUS
set serialrx_inverted = ON
set dshot_idle_value = 400
set dshot_burst = OFF
set dshot_bidir = ON
set motor_pwm_protocol = DSHOT300
set motor_poles = 12
set vbat_max_cell_voltage = 440
set vbat_min_cell_voltage = 320
set vbat_warning_cell_voltage = 330
set current_meter = NONE
set beeper_dshot_beacon_tone = 3
set small_angle = 180
set pid_process_denom = 2
set osd_warn_batt_not_full = OFF
set osd_warn_visual_beeper = OFF
set osd_warn_core_temp = OFF
set osd_warn_rc_smoothing = OFF
set osd_warn_fail_safe = OFF
set osd_warn_launch_control = OFF
set osd_warn_no_gps_rescue = OFF
set osd_warn_gps_rescue_disabled = OFF
set osd_warn_rssi = ON
set osd_cap_alarm = 450
set osd_vbat_pos = 396
set osd_rssi_pos = 2393
set osd_tim_2_pos = 2437
set osd_flymode_pos = 2445
set osd_vtx_channel_pos = 2452
set osd_crosshairs_pos = 2253
set osd_craft_name_pos = 2410
set osd_display_name_pos = 394
set osd_pid_roll_pos = 353
set osd_pid_pitch_pos = 34
set osd_pidrate_profile_pos = 2423
set osd_warnings_pos = 362
set osd_avg_cell_voltage_pos = 2404
set osd_disarmed_pos = 2379
set osd_flip_arrow_pos = 310
set osd_rate_profile_name_pos = 23
set osd_pid_profile_name_pos = 2
set osd_stat_max_spd = OFF
set osd_stat_battery = ON
set osd_stat_max_curr = OFF
set osd_stat_used_mah = OFF
set osd_stat_bbox = OFF
set osd_stat_bb_no = OFF
set osd_stat_total_time = ON
set debug_mode = DUAL_GYRO_SCALED
set scheduler_optimize_rate = ON
set vtx_band = 5
set vtx_channel = 3
set vtx_power = 5
set vtx_low_power_disarm = ON
set vtx_freq = 5732
set vcd_video_system = NTSC
set frsky_spi_tx_id = 82,142
set frsky_spi_offset = -33
set frsky_spi_bind_hop_data = 6,131,21,146,36,161,51,176,66,191,81,206,96,221,111,1,126,16,141,31,156,46,171,61,186,76,201,91,216,106,231,121,11,136,26,151,41,166,56,181,71,196,86,211,101,226,116,255,255,255
set gyro_1_align_yaw = 1800
set gyro_rpm_notch_min = 90
set name = AVELLA_THS1
profile 0
# profile 0
set dyn_lpf_dterm_max_hz = 250
set vbat_pid_gain = ON
set anti_gravity_gain = 9600
set feedforward_transition = 25
set acc_limit_yaw = 100
set crash_recovery = ON
set iterm_rotation = ON
set iterm_relax = RPY
set iterm_relax_type = GYRO
set iterm_relax_cutoff = 11
set iterm_windup = 40
set iterm_limit = 150
set throttle_boost = 6
set p_pitch = 105
set i_pitch = 125
set d_pitch = 95
set f_pitch = 100
set p_roll = 105
set i_roll = 125
set d_roll = 95
set f_roll = 100
set p_yaw = 95
set i_yaw = 95
set d_yaw = 45
set angle_level_strength = 60
set horizon_level_strength = 80
set horizon_transition = 110
set horizon_tilt_effect = 80
set horizon_tilt_expert_mode = ON
set d_min_roll = 0
set d_min_pitch = 0
set auto_profile_cell_count = 1
set launch_control_mode = PITCHONLY
profile 1
# profile 1
set dyn_lpf_dterm_min_hz = 0
set dterm_lowpass_hz = 100
set dterm_lowpass2_hz = 200
set throttle_boost = 3
set p_pitch = 70
set d_pitch = 55
set p_roll = 70
set i_roll = 90
set d_roll = 55
set f_roll = 95
set p_yaw = 75
set d_yaw = 13
set f_yaw = 106
set horizon
