RXSR Bound, not recognizing in BF
Kspearson1
Tyro 99 RXSR bound, but not recognized in BF.
I’ve got the blue and green light and the controller says it’s bound. But when I connect to BF, it’s like there’s nothing there.
Any ideas ?
It worked yesterday and I was messing around trying to get the motor changed but nothing with the RX.
Knowing nothing else, I'd start in the "ports" tab in betaflight. You should have serial RX turned on for the UART the receiver is connected to.
Then in the setup tab you need Sbus selected
[EDIT]
If you built it yourself and you're new at soldering, it could also be the signal wire for the RX. In that case it would bind but not speak to the FC
Anyone heard of Error RX_Failsafe MSP?
UART set at Serial RX
[EDIT]
Port setting looks good according to manual. From where I can see the green wire is soldered on but maybe I’ll undo some screws and take a look
Oh, sometimes it needs to be plugged in, the rx isn't always powered by the USB
[Edit]
Not sure I said that clearly. Once it's plugged into betaflight, try plugging a battery into the quad. It's likely that your RX simply isn't getting power through the USB. Some Flight controllers power up the RX through USB, some don't. I haven't found a rhyme or reason to it.
Reactions: Futuramille
az.lonewolf81
