So help getting off the ground
jerl77
So I bought a wizard x220
And I can't fly it lol
And simple programs for this drone
For a beginner? As soon as I start giving it throttle it starts going to the side and crashes
So far I only got a inch off the ground
Any help out there
Thanks jeremy
Reactions: simika
Have you connected to betaflight? I would do that and have a look at how the radio signals look on the receiver tab (take props off to do this). Each channel should read 1000min 1500mid 2000max. If they don't, you will need to adjust them in your radio endpoints and sub-trim menus while watching the bars on the betaflight receivers tab.
Reactions: JohnnyNotech
Any help out there
Thanks jeremy
jerl77 no panic.. i had a similar problem and i'm a newbie too! follow those steps and also have a look at this page (method 1) it saved me.. once I had all values in receiver (betaflight) set as they should be i still had that movement.. now I solved check it out:
How to trim your Accelerometer (method 1)
CleanFlight PID Tuning | OpenTX University
Sent from my BLL-L22 using Tapatalk
