Is it okay to have a zip tie flush with the exposed end piece of your reciever antenna and electric tape lightly. Or should the tip be exposed with no tape or ziptie behind it not flush if it's flush and taped will it give worse signal
I did not know that. Thank youCarbon fiber blocks a signal, keep that in mind
Thank you I actually designed a pivot wrap so it can pivot at 90 degrees up and to the back either one I want so I'll make sure to do the 90 degree towards back is best. So is bending my aomway 3dbi back not smart then if my reciever antenna is already going that direction. You want a 90 degree angle created by the two tightAlso, keep as far away as possible between VTX atenna and receiver antenna. Basic rule should be 90 degrees angle from each other if installed close to each other if possible. That's so your VTX won't cause noise in receiver & vice versa.
Yes. That would be best.Thank you I actually designed a pivot wrap so it can pivot at 90 degrees up and to the back either one I want so I'll make sure to do the 90 degree towards back is best. So is bending my aomway 3dbi back not smart then if my reciever antenna is already going that direction. You want a 90 degree angle created by the two tight
