VIFLY Finder 2 Wiring to CLRacing F4S
FrankV01
Chicago, IL
Website
theopensourceu.org
Hi, just a quick question on how to wire the VIFLy Finder 2 to the CLRacing flight controller.... (exact products with diagrams linked)
According to diagrams, the flight controller in question only has Buzzer+ and Buzzer- and there are three wires for the VIFly {red, white and Yellow}. The yellow to trigger the buzzer (I presume) at my radio's request (switch).
How can I wire the buzzer so that it works properly?
A little confusing as it's usually red, black and yellow. Red is buzzer + and yellow is buzzer - so white must be ground
Yeah, it's not exactly clear - the wiring diagram. The following is a screenshot from what I followed. Nothing exploded or smoked so I think it's right.
So, here's what I figured out from videos and a willingness to blow up my FC.
The black is ground. The yellow goes to Buzzer- and the Red goes to Buzzer+.
You can put the black on any ground pad (which is fairly common knowledge, I think). The confusing aspect was how to wire the red and yellow to (1) allow the unit to charge it's internal battery, (2) allow it to work as a traditional buzzer and (3) allow it to work as lost model buzzer as advertised (battery ejected type thing).
I think the above/below is right. it's what I followed, anyway.
3309
Reactions: RENOV8R
Yes, that's correct. You can now set up a switch on your taranis to control it manually
Reactions: FrankV01
Soso
