vtx rush tank solo problem
gio
Hello, I have recently installed a rush tank solo on my drone, having already had a rush vtx before, I didn't have to solder a new connector but I used the one I already had installed. I was configuring the vtx table on betaflight and checking the type of table that I should have downloaded I noticed that the number in the sensors page did not correspond to anyone present on the site (318) instead 316 is present. I installed my number. Once the configuration was finished, I turned on the drone and tried to calibrate the module to find the correct band and channel but trying several times the module does not detect any signal from the vtx. I have been in front of the pc for hours but I can not solve it, I hope someone can help me, thanks.
Hay mate I'm having the same issue my rush tank solo has been working fine for months now nothing is working it powers on but no picture. Did you manage to fix your one
