What is the correct SD card the buy for the Avata and the Integra
This is the card that I am using in my Avata, FPV, and Air 2S, and I have had no problems at all.
Highlights​
  • 256GB Storage Capacity
  • A2 / UHS-I / V30 / U3 / Class 10
  • Max Read Speed: 190 MB/s
  • Max Write Speed: 130 MB/s
  • Min Write Speed: 30 MB/s
  • Records Full HD, 3D, and 4K Video
  • Water / Shock / X-Ray Proof
  • Can Withstand Extreme Temperatures
  • Built-In Write-Protect Switch on Adapter
  • Downloadable RescuePRO Recovery Software
Features​
Designed for microSD devices such as smartphones, drones, and action cameras that can capture Full HD and 4K video, as well as raw and burst photography, the 256GB Extreme UHS-I microSDXC Memory Cardfrom SanDisk has a capacity of 256GB, is compatible with the UHS-I bus, and features a speed class rating of V30, which guarantees minimum write speeds of 30 MB/s. If your device does not support the V30 standard, this card also supports the U3 standard, which also guarantees minimum write speeds of 30 MB/s. Read speeds are supported up to 190 MB/s and write speeds max out at 130 MB/s.
While this card has been designed for cameras that are UHS-I / V30 / U3 compatible, it may be used in devices that do not support UHS-I / V30 / U3. However, bear in mind that this card will then default to your device's speed class and bus rating, such as UHS-I and U1, which supports minimum write speeds of 10 MB/s, or Class 10, which also supports minimum write speeds of 10 MB/s.
i just bought the
Gigastone [5-Yrs Free Data Recovery] 128GB Micro SD Card, 4K Camera Pro, A2 V60 MicroSDXC Memory Card for Smartphone, Gopro, Action Cams, 4K UHD Video, Up to 120/80 MB/s, UHS-I U3 C10 with Adapter.​
No problem with Freeze or hanging of the video.
Thanks for your thoughts.
Reactions: SWTSU
bullbloke
