what will i need to replace the motors in my eachine wizard x220 v2?
Rosssiiii
Hello :)
i open that discussion because i have to replace the motors in my eachine wizard x220 v2 but i want to know what i will need to complete the operation in fast way.
1) a soldering iron ;
2) i have to remove that tape ( ) and i think i will need other like that, what kind of tape is that ? or is possible reuse the same ?
3)in order to weld the motors on the esc, I think it will be necessary to remove the heat shrink tubing, so will I need another heat shrink tubing?
looks like a difficult operation for first time
I would remove the tape on either side, cut back the heat shrink a little, solder the motor on and put electrical tape over the ends of the ESC's. Or if you have the correct size heat shrink you can cut off the heat shrink, slide up new heat shrink, replace the motor, heat the heat shrink.
Reactions: Rosssiiii
Mfett
