Wizard X220s VTX
Hi I have checked the voltage and seems ok to me,
I have tried two different cameras and bypassed the F.C. and all is ok.
I did notice the video on cable to the F.C. was split so I soldered in a new harness from the camera this did work I powered on and hovered and then it went black again and now I can get it back. I will check the settings but pretty sure they are right
Thanks
I would replace any video wires that have not already been replaced. Did you check for continuity on both video wires with a multimeter when it goes black?
I haven’t yet I don’t have a multimeter I borrowed a friends to test the power.
It does seem strange that the cable looked dodgy I’ll try and replace everything tomorrow
I have wired the camera straight to the vtx and it works great, I have replaced the video wires but when run through the F.C. I still get the black screen
Thanks
It sounds like the OSD chip is probably bad, but you could try to reflash the fc. I don't know how likely that is to work, so if you aren't comfortable reconfiguring everything after a flash, it may not be worth it to you.
Thanks Green
I have already flashed the flight controller but it didnt change anything and I have check the F.C. for anything untoward but can’t see anything
Thanks
I have been in contact with the seller and they agree that the Flight controller is defective and are sending me a new one out, i just have the fun of trying to solder the new one in.
so might be back to ask some more questions :D
Thanks
Hi All
i have just been looking and have noticed that the Seller is sending me out a Omnibus F4 V5 FC it looks the same as the one thats in my wizard x220s but just wanted to check with you guys and make sure i can basically mirror the wiring on my faulty FC
Thanks
