Another Noob 3d, but I don't want to make mistakes..
enigmo
I fly dji products hubsan 501s and a small x4 107L. I consider myself pretty good with it but, of course, the next step is getting into fpv. I can solder and I usually fix everything myself if a motor or led stops working. However, I am looking for something ready to fly. I can't spend a lot of money (I wish I could).
I watched the $300 racer wizard video and I was about to buy all the things the guy listed
(for reference
I also found the walkera runner 250 in my price range (I just need to add a pair of goggles).
I wonder if you guys can suggest the best way to go knowing I can't spend a lot of money. I just want to get into the fvp experience.
Again, I need the full package (quad+controller+goggles).
Enigmo,
Welcome! This is a tough one that we've all confronted. I went a bit this route on my first FPV quad. I bought an Arris X-Speed 250B that included the Radiolink AT9.
https://www.amazon.com/gp/product/B015ST5UPM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
It was a great way to go for me as I was totally oblivious to racing quads. I then checked out and tested various goggles and wound up with the Fatshark Dominator V3's because I could also use them with my Phantoms.
I then found myself looking at and learning about the various flight controllers and wanted to upgrade the FC, then I wanted a better camera so I bought a RageCam, then I saw another ARF bird I wanted, then I needed a different radio and ended up getting a Taranis Plus....
Are you getting the drift? I can't answer your question. The only thing I can say has been said a zillion times before, you get what you pay for. I now have 3 FPV Quads, 10+ batteries, chargers, parallel charging boards, Lipo testers, extra cameras, flight controllers, transmitters, straps, props, tools, etc.
Sorry, wish I could have been more help!
Welcome!
You can see what has happened to me in this thread:
Almost ready for the Texas Trip!
The RTF Eachine Wizard on banggood is a solid choice. For cheap goggles, Eachine EV800 are pretty good. I am not some big Eachine fan, they just happen to have some very good budget stuff right now.
Thanks! I may go with the wizard. The video suggest a 1300mah 4s battery. Should I go with that one or a different one? As a beginner a 3s may be a better choice?
I am reading that the wizard is not really good for fvp tho because of the narrow field of view. Also, the falcon 210 seems a little bit cheaper. Is there a noticeable difference?
FOV is a property of the camera, specifically the lens. The Wizard is designed specifically for FPV. It is a matter of preference how wide FOV a pilot needs. If you don't like the FOV it has, you can put on another lens for about $5. Lots of people use a GoPro lens on their FPV cameras.
Link for the Falcon 210? I saw one on banggood but it is sold out. Also it does not show full parts list.
Yea I think it's the one on banggood. I didn't notice it was sold out.
The Falcon won't even show up in search for me now. But Wizard has BLHeli_S ESCs which is better and I think a couple other upgrades. It is also based on a clone of a proven premier frame, the Luminier QAV-R. I like the Wizard, it is a crazy good deal.
As a side note, I live very close (less than 1 mile) to getfvp. Now, they are not really a store since they work online but I wonder if I can just walk there and ask if they have some good deal for a beginner.
Well the wizard is def on top of my list. I am just scared because as a total beginner I am not sure I will be able to handle of the settings etc...
GetFPV is a cool site, I got my VTX from them. But a QAV-R from them will set you back $500 with very similar hardware to the Wizard. If you want a pre-tuned quad, also check out DroneProz.com . They aren't super cheap, but they tune evrything including PIDs for every drone they ship. If you are worried about the setup, that may be a good route. It will cost a lttle bit more than double the wizard's price though.
Yea I;ll take a look but the wizard seems the very best way to jump into fpv.
Yeah, I wouldn't worry too much about setting it up if you get RTF. And if you take it slow at first, nothing will really break when you crash on grass except props.
(for reference
I had the same problem trying to get a cheap racer I started off with Dji Phantoms but made the switch to fpv glad I did. I started with the 250 class storm racers from heli pal then discovered the vortex which is bad a.. also I started off running 3s then made the switch to 4s you will have to find your way through all of this I have spent so much money and time on all of this. I had to spend big money on the goggles what a big difference when you compare visually. The dominators rule. It's go big or go home.
Specter72
