Can I mount my VTX directly to make carbon fiber frame ?
broncosdad1317
Wisconsin
can I mount this vtx straight to the carbon fiber of my frame. Even if the corners are metal as you can see in the pic or does it need to be put on a stack. Is there a way to make it work being mounted directly to the frame maybe some electrical tape between and or heat shrink. It gets pretty hot didn’t want electrical tape melting to it or something
Would double sided mounting tape be the same thing. Like a thicker foamy double sided tape. I have some of that. It won’t melt from te high heat emitting from vtx?
CollatixWolfe
