once you download those two and you connect to your fc, give it a few mins to install your drivers, dont touch anything untill your gfu opens up. This is where a lot of people make mistakes
so got the two files loaded.. then got and pointed at the .hex for pico (betaflight_3.2.0_PIKOBLX.hex)
cp210x and stm esb drivers are installed.
still can't connect and getting "no response from boot loader, programming: failed"
what am i missing?
i got the quad connected. tx/rx is bound but. . do i plug the tx into the computer in boot mode (taranis x9d). i did the port settings, serial rx and sbus.. bound the tx to the rx.. tx won't connect in betaflight
Sounds like you are using the wrong receiver protocol or something, check your ports, and receiver tabs over, make sure to hit save after changes
tried with it connected and not. i see the taranis as a joystick peripheral so its connected. ports are set like this... still nothing. went by the YouTube vid for the pico fc
taranis x9d plus sbus
xm+ rx
it binds to the quad just fine but not showing input in betaflight. quad is fully connected in betaflight.
seems betaflight and my tx don't like each other. i got the port settings from furious YouTube vids..
nemanja
