Connect DJI Black Radio to Vista Nano?
As mentioned if you have the DJI RC and want to use it you need to connect the signal wire from the Vista to the FC's SBUS in if it's not already there and set up the FC to use it. The manual for the Vista has some guidance for that.
Thanks Kilrah, I'll stick with with the iF8 receiver for now. I'm asking more to understand why the DJI controller didn't work but still was able to bind..
Is the sbus on the FC dedicated to a receiver control inputs? The fact that my Vista card has an sbus, does that mean there's a built in receiver? There's also a Grn that isn't used, does that have to be wired? I assume there's only one sbus on a FC right? I'd have to disconnect the other I suppose.
I'll try to answer some of your questions.
1 Is the sbus on the FC dedicated to a receiver control inputs?
Yes it is dedicated to whatever receiver is wired to that pad.
note wiring 2 receivers to that pad at the same time will not
work .
2 The fact that my Vista card has an sbus, does that mean there's a built in receiver?
Not necessarily, But the specifications of the Nano VISTA unit
say it does so in this case Yes.
3 There's also a Grn that isn't used, does that have to be wired?
Yes but the other end would then have to be wired to the
SBUS pad on the FC instead of the wire from the iflight receiver.
4 I assume there's only one sbus on a FC right?
Yes in the case of your FC.
5 I'd have to disconnect the other I suppose.
Correct.
work .
Correct.
Thank you Terry.
Specter72
