would you recommend that i just send it back to diatone in china for repair of the original parts or should I try to just switch to a new fc, i dont think i want a drone that im not able to understand. I can email them and ask for a better pinout of the esc, i didnt think it would require very much work other than unplugging the old fc and swapping all the connections, the esc already has the motors and everything wired up, all im trying to do is replace the fc and vtxThat can be a problem when hooking these kinds of things up. The pictures above show VCC from the ESC to the FC UART, that will smoke the UART and likely the whole FC as soon as you plug a battery into it. If I could find any decent docs on the Diatone Black Mamba F40 4in1 ESC I could give you some pointers but I can't seem to find anything with a quick google search.
Just as FYI, often labels can be misleading, especially when translated to english by Chinese manufacturers.
Usually VCC is battery voltage, and you will need a +5v regulated source to run the FC, but the translation could be wrong or misleading and that could be +5v out from the ESC. No way to know without documentation on the mamba. The SPRacing F3 is a well known item, I have 4 of them, but I would need to see the wiring diagram for the ESC to even begin to help here.
From there the Motor Signal wires (the section labeled "10" above on the FC) will need to go between the FC and the 1,2,3,4 labeled pins either on the connector on the face of the ESC, or to solder pads that should reside somewhere else on the ESC. There really is a good bit to understand here in order to get it connected and working properly, even if it has all the things you will need.
figured id give a pic of the situation as wellThat can be a problem when hooking these kinds of things up. The pictures above show VCC from the ESC to the FC UART, that will smoke the UART and likely the whole FC as soon as you plug a battery into it. If I could find any decent docs on the Diatone Black Mamba F40 4in1 ESC I could give you some pointers but I can't seem to find anything with a quick google search.
