A new version of Flight Reader is available. Release 1.7.5 includes the following changes:
Added support for processing Matrice 4T flight logs.
When processing a flight log, a snapshot of the flight path is automatically generated and displayed in the "Photos" column of the flight list in the main Flight Reader window (view demo).
The RC.aileron, RC.elevator, RC.rudder, and RC.throttle values are now grouped together on the same chart axis for enhanced readability.
Resolved a crash that occurred when loading the Aircraft History while the "Aircraft" column in the flight list of the main Flight Reader window was hidden.
See the release notes for a complete list of changes.
A new version of Flight Reader is available. Release 1.7.7 includes the following changes:
Added support for processing Matrice 4E flight logs.
The “Home point updated” message is now suppressed when the home point shifts less than a few inches. The generated aircraft log will still record these minor adjustments for models affected by what appears to be a bug in the DJI flight log creation process. However, since the change in home point location is minor, it’s no longer included in the “APP.tip” field.
A new version of Flight Reader is available. Release 1.7.8 includes the following changes:
For drone models with dual batteries, the serial numbers for both batteries are now stored in the SERIAL.battery and SERIAL.battery2 fields.
Serial numbers can be found in the RECOVER.*, DETAILS.*, and SERIAL.* fields depending on where they are extracted from flight logs. All serial numbers have been combined together and stored in the SERIAL.* fields. When referencing serial numbers, use the SERIAL.* fields as they now provide the most complete data.
Added more size options to the Log Viewer Map Size setting in the General section of the Flight Reader Options window, allowing greater customization of the Google Map height in the Map log viewer.
Flight path markers on the Google Map are now only displayed when the home point is initially set or manually reset by the pilot. While small automatic home point adjustments, such as those made by drone models like the Air 3S, are still logged in the APP.tip field with "Home Point Updated" messages, they will no longer appear as markers on the Google map to reduce visual clutter.
A new version of Flight Reader is available. Release 1.7.9 includes the following changes:
Resolved an issue that prevented photo and video data from being extracted from Mini 2 flight logs.
When opening the map view for a processed flight log, the map will use the current “Log viewer map size” setting from the “General” section of the Flight Reader Options window instead of the size that was selected when the flight log was processed.
A new version of Flight Reader is available. Release 1.7.12 includes the following changes:
Added a new OSD.tiltInclination field to display the drone’s overall tilt angle, showing how much it leans relative to a level horizon during flight.
Add new fields DETAILS.droneManufacturer, DETAILS.droneModel, and DETAILS.droneManufacturerModel allowing the drone’s manufacturer and model names to be shown separately or combined.
C1 and C2 button presses from all DJI RC remote controllers are now captured in the RC.custom1Depressed and RC.custom2Depressed fields.
Resolved an issue introduced in Flight Reader version 1.7.9 where the CAMERA.isVideo field could incorrectly remain set to True after video recording stopped.
A new version of Flight Reader is available. Release 1.7.21 includes the following changes:
Added new fields RTK.aircraftGeoidHeight [ft] and RTK.aircraftGeoidHeight [m] to display the geoid height offset at the aircraft’s location based on the EGM2008-1 geoid model.
Renamed RTK.aircraftAltitude to RTK.aircraftEllipsoidalHeight to better reflect its meaning.
Updated RTK.aircraftAltitude to show the calculated ASL altitude value using the EGM2008-1 geoid model.
Fixed a crash that could occur when right-clicking a column in any generated log and selecting Hide Column.
A new version of Flight Reader is available. Release 1.7.26 includes the following changes:
Added the option to display the OSD.flyTime field in charts, allowing you to view the current flight time in minutes and seconds.
The flight map snapshot now uses OpenStreetMap as the default map source. To use Google Maps instead, you can enter your Google API key in the API Keys section of the Flight Reader Options window.
Resolved an issue where the After processing log file action (configured in the General section of the Flight Reader Options window) was not triggered when importing a flight log via File → Import Flight Log in the main Flight Reader window.
Resolved an issue that caused the Google Map to fail to load in the map window.
A new version of Flight Reader is available. Release 1.7.34 includes the following changes:
When the Map Data Resolution setting is set to Only Notable Events Only (the default), Flight Reader now updates the flight path and events whenever the aircraft is moving. In previous versions, small movements were not recorded unless the Show All Available Flight Data option was selected.
If a DJI TXT flight log contains incorrect values in the DETAILS.photoNum or DETAILS.videoTime fields, Flight Reader now automatically replaces them with accurate values based on the actual photo and video data extracted from the log.
Resolved several decryption issues that previously caused some flight logs to fail to process.
A new version of Flight Reader is available. Release 1.7.40 includes the following changes:
New Event CSV and Video CSV options are available under the Export menu. The Export menu will only appear in the context menu when selecting multiple flights and right-clicking in the main Flight Reader window.
A flight polygon KML is generated during flight log processing to visualize the flight area. Access this new KML by right-clicking a flight in the main Flight Reader window and selecting KML → Flight Polygon KML.
Added a new CAMERA.mode field to indicate when the camera is shooting in Single Shot, Multi Shot, Pano, or Video mode.
Added a new CAMERA.photosTaken field to show how many photos were captured. This value will be greater than 1 during rapid-fire photo modes like AEB or Burst.
Added a new CAMERA.panoPhotoSequence field to indicate the sequence number of each photo in a pano sequence. This can be used to group photos from the same pano sequence.
Rows are now highlighted in green wherever a new video recording begins in the Video Log.
The CAMERA.isPhoto field now logs a single photo entry at the moment each rapid-fire photo (e.g. AEB or Burst) is taken. The new CAMERA.photosTaken field shows how many photos were captured at that moment.
AM/PM designators are now automatically added to 12-hour time fields when using a Windows region that does not have them defined. In previous versions of Flight Reader, missing AM/PM designators made it unclear whether times were in the morning or afternoon.
The Measurement Units setting in the General section of the Flight Reader Options window now defaults to the user’s Windows region settings when this setting has not been set.
Resolved an issue that caused an extra photo to be incorrectly documented at the end of each pano photo sequence.
Resolved a crash that could occur when loading a malformed CSV file. Instead of crashing, Flight Reader will now display the malformed data. Reprocessing the flight log may fix the issue.
Resolved an issue where an incorrect flight start time could be shown when a second flight begins without powering off the drone between flights.
Fixed an issue that sometimes prevented flight logs from being processed when importing via File → Import Flight Log… in the main Flight Reader window.
A new version of Flight Reader is available. Release 1.7.43 includes the following changes:
Added the ability to double-click any row in the log viewer to quickly highlight or unhighlight it for easier reference.
Implemented a new algorithm to precisely track and document the aircraft and gimbal positions where each photo was captured during a pano sequence, improving the accuracy of photo location data.
Resolved an issue that could cause the CAMERA.photosTaken count to display incorrectly when capturing rapid-fire photos (e.g. AEB or Burst mode).
A new version of Flight Reader is available. Release 1.7.48 includes the following changes:
You can now right-click multiple selected flights in the main Flight Reader window and generate reports from the Reports menu for only those selected flights.
Added an optional Flight Number column to the flight list in the main Flight Reader window, showing the order in which flights occurred. To add this column, right-click any column header and select Customize Columns.
Resolved several issues that could prevent flight logs from decrypting successfully during processing.
A new version of Flight Reader is available. Release 1.8.3 includes the following changes:
Improved application stability by addressing possible crashes that could occur after the Flight Reader splash screen appears.
Resolved an issue where the CAMERA.mode field incorrectly displays “Multi Shot” and report three photos in CAMERA.photosTaken when taking photos in Hyperlapse flight mode.
Resolved an issue that could incorrectly notify users that a newer version of Flight Reader was available while already running the current version.
A new version of Flight Reader is available. Release 1.8.5 includes the following changes:
Populated the previously empty BATTERY.usefulTime field for newer DJI drone models, including the Mini 4 Pro and Mini 5 Pro.
Resolved an issue where selecting Last Year from the Flight Date dropdown could incorrectly include flights from the current year, ensuring only flights from the previous year are displayed.
Resolved an issue that could prevent KML files from being generated when processing flight logs containing non-English text in KML marker messages.
