DJI Goggles V2 - Bateria com problema?
marcos morais
Minha bateria liga e desliga em seguida. O que fazer?
DJI Goggles V2 - Battery problem?
My battery turns on and then off. What to do?
Are you doing the double press or just single. If single it will just give you the charge reading not power up. If double, make sure it's quick press then press and hold till you see it turn on
And to repeat, the cable must be plugged in to the battery (goggles don't matter). It will not turn on otherwise.
like rtkman said, make sure usbc is realy pushed in, now I remembered I had a oroblem with the conenctor seeming to be in, but you have to push in further,I guess that's why the goggles 2 have the clip
fpvtune
