Eachine trashcan motor problem
Mcknight
Hello everyone,
I have a problem with my tinywhoop eachine trashcan.
At first i had a problem with the receiver not finding any input. Got that solved now, however now i am running in to another problem.
The problem i am encountering, the moters max out when i arm the drone and push the throttle. So the drone shoots up. Disarming it works fine.
Does anyone know why this problem occurs and how i can fix it?
I checked the betaflight conf. The motors are reversed as it should be.
Double checked the props aswell.
So it arms and idles fine, but as soon as you give it a little throttle it goes to full throttle?
Do you have it set for SPI RX?
az.lonewolf81
