Eachine x220S LED issues
Pmac_84
Melbourne, Australia
Hi All,
Long story short - lost my x220, bought an x220s - all running fine, but i'm not sure about the LED tail setup...
Am i wrong in thinking i should be able to config the LED's individually? and i'm sure i read somewhere that they're RGB??
They all light up white and the buzzer works fine - but i can't seem to set them up to change colour?
Assuming the standard LED strip on the x220s is RGB - the left side should light up red based on my below config?
Is there something i'm overlooking?
**I do have lipo attached and still no change.
Any help, as always is much appreciated!
Eachine Wizard X220S FPV Racer RC Drone Spare Part Taillight Tail LED Light with Loud Buzzer
The LEDs are programmable
The LED wiring needs to be relative the the quad, as you look at the at the wiring layout from your screen shot the top is the front of the quad and the bottom is the back of the quad you need to set up the LED wiring as they are on the quad i have done a crude sketch for you
Thanks for the response.. I have tried different locations on the grid with no luck - i'm sure its something small i'm missing but just can't figure it out!
Darmie
