Esc Calibration
FpvDemon518
Cobleskill New York
I loaded the new firmware for my Naze32 rev6 on beta flight then went to calibrate the oneshot125 with the battery unplugged went to the motor section checked the no prop then clicked the master put it all the way up at 2000 then plugged the battery in the motors ramped to 2000 help
Can you show us of video of this? I think you plugged in your lipo too soon.
One tip. Adjust the values in BLheli instead of calibrating using the mastertab. Use 1020 as min and 1950 as high value and you should be good.
Notubesmaster
