Flight Controller + Receiver (FIRST TIME BUILD)
Jamesjoshua3
Hi everyone, this is my first drone build for a school project, I'm running 4 Turnigy motors, 4 30A ESC with BEC connected to a Diatone V8.3 LC Filtered PDB. The PDB is connected to my 11.1V 3s lipo battery all of these parts that i have mentioned so far are connected and work properly , from there i have an OMNIBUS F4 V6 flight controller, this is where im confused, i cannot figure out where the radio wire goes on the flight controller and on top of that i have a range of 4 receivers (NE 480348, OrangeRx R620, FrSky X4RSB 3/16ch 2.4Ghz ACCST and a FLy Sky FS - R6B, all of these are 6 channels +) and my transmitter is the Fly Sky FS-CT6B. my question is which receiver if any will be the best for my currest setup and how and where do i wire it to my flight controller? sorry if this is a stupid question, just really lost at the moment.
The FLy Sky FS - R6B is what you want for your receiver, and I think you're putting it to RX3. Then you'll have to make sure that port is on in betaflight. I'm not positive because I don't use flysky, but I'm pretty sure it's not inverted so you won't use sbus. I think some of these guys use flysky, if you don't get an answer I'll look harder for you
Thankyou, i will try it tonight and let you know how it goes.
Don't think so. As you have a FlySky transmitter, the only receiver compatible is the FS-R6B. But only puts out a PCM (1 wire per channel) signal which is not compatible with the Omnibus FC. It wants PPM or iBus signal
IolaLuther
