Having trouble activating your V2 goggles and you don't have the DJI FPV drone
It appears some people are having activation issues with their new DJI v2 goggles because the activation process is looking to also connect to the drone. It appears this may be related to goggles that had a pre-release firmware intended to work with the drone prior to launch date. Some of these goggles may have been sent out to consumers who purchased the v2 goggles. DJI has a temporary workaround for those users.
V01.00.0606 update
Login to DJI assistant 2 with the following DJI account:
User: [email protected]
Pass: DJI123456
  1. Go to settings in assistant 2 and enable "DJI Account Information" and "DJI Device Information"
  2. Connect the goggles and update to V00.05.1086
  3. Disconnect from DJI assistant 2 and in the goggles menu, go to... Setting... About... and switch the mode to DJI FPV digital system and click ok
  4. Reboot the goggles
  5. You may see a notice of activation screen in the goggles
  6. Connect the goggles again to DJI assistant 2 and follow any prompts for activation.
  7. Once complete, update the firmware to version V010.00.0606
You should now be all set and ready to use your goggles with your air units or vistas.
This information has been posted on the DJI forum and also on may other sites. It is a temporary workaround from DJI and will only be needed for some of the inital goggle sent out. This process will be retired once DJI believes it is no longer required. It is not confidential information and sharing this temporary account password is of no concern to DJI.
Oh my. Sifting through miles of threads and videos, and this finally worked. Notice this is 9 months after your post... Thanks DJI. But really, thank you so much.
LonaS324
