Help required for correct setup!!
LDP
Hi there here is my dilemma!!
My transmitter is a spectrum DX7
My receiver is a spectrum an AR6200
My racer is the Eachine Racer 250
The problem I need assistance with is setting them up and getting them to talk to each other and work correctly.
Problem one, (what came first the chicken or the egg)
Do I need to program racer first or program the receiver and transmitter first?
If I need to program the racer first do I only need to connect USB Cable and use libre pilot or do I need to power up with the Main battery and use the USB cable. As presently I cannot get it talk or connect with libre pilot.
Is this due to the fact I am doing incorrectly all that I have missed something out!!
Do I have to set up the TX and RX first before I am able to programme the racer and if so does anyone know how do I might go about this as it is not the most straightforward process as far as I can make out regarding correct settings and so on!!
Please if anyone can help I will be eternally grateful as I have been racking my brains trying to find a solution to no avail and I what to get this puppy in the air!!!!
You will need to do a few things, assuming they haven't been done.
1. Bind your receiver to your transmitter. See YouTube for spektrum specific videos.
2. Connect to LibrePilot (or cleanflight, betaflight, etc). Begin with a CC3D drivers video on YouTube.
3. Configure LibrePilot (or cleanflight, etc) for a spektrum serial receiver.
4. Calibrate the radio to the desired range and midpoint for each channel (throttle, pitch, etc).
Reactions: kris660
Thanks very much for getting back to me so quickly.
I'm here in the UK so is nighttime 22:36 so will have a go at this tomorrow and let you know how I get on!!
Cheers for that.
Reactions: theGreenOrange
hi again i keep getting the timed out notice what am i missing?
screen-shot-2017-05-02-at-08-03-10-png.698
either your usb cable is bad or you dont have the right driver, try downloading the impulse rc driver fixing tool
Make sure you are not using a charge only usb cable. You need one that can transmit data. Test by connecting your phone to your PC. If that works then it should work on your quad.
Texecdeza
