Help with receiver pairing
jtwood25
Working on my first 5 inch quad and am trying to pair my racerstar 30amp fc aio and my flysky radio. I have a family-ia6 receiver my transmitter shows an rx battery level which means it’s paired and my receiver is solid red which means it’s paired but the fc is still blinking green and the transmitter does not show up in beta flight. Any suggestions?
It might be the cable connecting it to the computer try a couple different other cables
If you are not able to connect with BF, you may not have all the drivers installed to enable it to run. I had a similar problem and could not connect until I sorted that out. Once I connected, I had to update BF to the latest version and I could have a play. Also I use a is-6b receiver as the is-6a wouldn’t bind despite it appearing to do so.
Your FC is probably trying to use a different protocol for your receiver than what the transmitter is using. FlySky typically uses PWM/ PPM or iBus. You'll need to get your Betaflight connection working properly first so you can configure the correct protocol. Your PC has to have the correct USB driver installed and also the proper port used when you plug in the quad,
