Holybro Kakute F7 V1.5 Flight Controller
Tonell
Hello guys,
I want to tell you that I'm new in this hobby and I have some question.
So I have Holybro Kakute F7 V1.5 Flight Controller and I want to go with the DJI air unit. I want to know where I should put the wires on the flight controller.
I want to tell you that I use 4S lipo.
Can I put the red wire on the B+? the black on above B+?
I know that: white: UART RX on R1 and gray: UART TX to T1
But where should I put the brown and yellow wires?
I have attached an screenshot with the Flight Controller
I want to mention that I use Frsky taranis x9 lite s.
I will appreciate if I will get an answer.
Hello guys,
I am pretty sure you have the red and black correct and the attached pic shows where I think the brown and yellow go as well.
Someone else who has the DJI Air unit should chime in to verify it though.
I am pretty sure the yellow is the built in RX in the air unit for those that use the DJI remote, don't think you hook it up, and if you did it would go to the RX UART (port) that you would configure for Serial RX and Sbus (until BF finally releases a rev that supports DJI HDL, then that will be a new choice in the Serial Provider drop down in BF), but that is ONLY if using the DJI FPV remote.
IolaLuther
