I thought it might be helpful to the small few that actually have both v1 and v2 goggles and use stock antennas.
The antennas on the DJI v1 and V2 digital FPV goggles look the same from the outside, but on the inside they are quite different. The version 1 FPV goggles operate on the 5.8GHz frequency band. The antennas are tuned for optimal performance with these frequencies. The V2 goggles operate on both the 2.4GHz and 5.8GHz bands and the goggles / DJI FPV drone can switch back and forth to either one to maximize bandwidth and range. This means the antennas have been tuned to support both of these frequency bands. Using the V1 antennas on the V2 or vice-versa will result in inefficiently tuned antennas being used and sub-optimal signal transmission and reception. The net effect will be reduced range and potentially more latency. So using the right antennas is important.
So what if you already owned the V1 goggles and now also have the V2 goggles and you remove the antennas for transport but accidentally mixed them up. Are you destined to an ( Mod Removed Language)of questionable range and efficiency? Will you need to live with the life-long regret of not marking those new antennas before you even put them on the V2 goggles? Luckily no... There is a simple way to tell them apart. The V1 antennas weigh more than the V2 antennas. On my food scale, the V1 antennas weigh 5.5g whereas the V2 antennas weigh 5g. There you go, now identify those bad boys already so you don't have to walk around with a scale in your pocket!!
