In preparation for the arrival of my custom 3" TGO SE...
Jtrjr
Texas
Website
www.youtube.com
...I broke out my piece of crap Diatone DT130 to see if I could get the thing running well enough to start practicing with a smaller bird. The thing had no guts, the FPV camera sucked, the SP2 VTX (usually a decent VTX) got no range at all and it had no low battery warning. It also provided no method to mount an HD camera. Just a POS (expensive) bird.
So yesterday morning I stripped the thing down. I found some really crappy solder joints on the VTX and the FC which I painstakingly fixed. The antenna lead wire was somewhat kinked, I was able to fix the kink and I worked the lead into a loop with my heat gun. I replaced the crappy FPV Camera with a new Runcam Swift Micro V2 that also has a bare bones OSD with Voltage info. I replaced several motor mount screws that were missing. I upgraded the VTX antenna to an Emax Pogada II. I fixed a few bad solder points on two ESC's. I then took a camera mounting plate from my Crusader GT2 inventory and fitted it for the top of the DT130. I mounted an old Runcam HD camera to the top of the bird.
I used the camera OSD to set all of the camera settings. I put a Venom 3S 850mah 75C and put the sucker in the air. It ain't gonna be no TGO SE but it is night and day from the bird I bought! For such a little bird with an HD camera mounted to it, I'm impressed. I'm flying it to almost the same range as some of my better birds (obstacles affect it worse than my others) so the bad solder joints and kinked antenna lead were definitely an issue. The Swift Micro V2 is awesome for this style of bird and I love that I now know my battery voltage. All-in-all, I'm quite pleased with it. (Video to follow)
Now I can get a little practice in with a small bird before "THE BOMB" shows up!
IMG_8150.JPG IMG_8151.JPG IMG_8152.JPG IMG_8153.JPG IMG_8154.JPG IMG_8155.JPG IMG_8158.JPG IMG_8160.JPG IMG_8162.JPG IMG_8163.JPG
View attachment 1136 View attachment 1137 View attachment 1138 View attachment 1139 View attachment 1140 View attachment 1141 View attachment 1142 View attachment 1143 View attachment 1144 View attachment 1145
Nice!
Thats the same frame im using on my three inch sans pod, im shooting for low profile
Yeah, the stock side plates are twice as high as they need to be with the new swift mini cam installed. I might mod the heck out of this thing if it actually holds up for a while. These smaller birds are a blast to fly! The TGO SE is going to be awesome!
