Loctite motors?!?!
broncosdad1317
Wisconsin
so I've read and heard controversy around the net but I only am gonna trust what the family here has to say....so.....should I loctite my motor screws? What kind of Loctite? What screws? how much for application? how long to dry before an aggressive flight?
No debate, answer is absolutely. Particularly if using soft mount plates. Just a little dab on the end of the screw, doesn't take much
Use blue Loctite, not the red permanent stuff.
I use only high quality steel screws, don't see any benefit in using alum or titanium. Some people use only 2 of the 4 screws, that's just personal preference, I use all 4.
As for length, just eyeball 'em. As long as they're flush with the bottom plate or protruding a mm or 2 is fine, as long as they're not close to making contact with the windings. I let them set up for a minimum of 24 hours
Donrabeja
