Logical Switch Question
Torc
Cincinnati
Website
www.youtube.com
I set up a two switch arm (sh+SF) and I'm trying to figure out if it can be set that a sound only plays if arming was successful, not anytime it's flipped.
I tried to I add LO1 to the mixer but was unable. Is this a possibility?
I don't think there is any indication that would tell the TX that arming was successful unless you can figure some way to read a telemetry value that might indicate running motors, but I cant think of anything off the bat that would do so.
That is the EXACT same thing someone I asked earlier said. :)
This would be only within the tx, no input from the FC. Just an alert that the switches were properly flipped.
You may be overthinking things a bit. Firstly, if your quad is set up properly it should always arm. Secondly, the indication you get that you're properly armed is the fact that the motors spin up.
And exactly what I said to myself!
Glad to know I'm on the right track. [emoji16]
I thought I'd ask to see if it was possible but as you said, not needed.
buck
