Mobula 7 HD locks up in BetaFlight
krashking57
Madison, FL
Just received my mobula 7. Setup my QX7 and the bind is complete. While in Betaflight and setting up all the parameters, it locks up as soon as I click on 'Modes' to set up the Aux switches. The screen is basically blank, only one little arm window comes up, no slider and no other channels. On the receiver tab, everything works as it should when moving the sticks and switches. Bad FC board??? never mind, updated firmware solved it.
I was going to suggest updating the FW but you’ve already done that. Oh, and bind it in D8 to help prevent the dreaded mini ‘failsafe’ events those FCs are famous for.
az.lonewolf81
