Motor spins up more than others.
iKnight
Hey guys. Another day, another problem with my x220s wizard.
So I have everything set up in betaflight, and when I arm the quad, all the motors spin. However, when applying throttle (in only one direction), only 1 motor revs up more. The other motors only rev up when moving the sticks in other directions. Furthermore, my ESC seems to have a constant beep that occurs every half a second or so. What could be causing this?
Turn off Air Mode and set the quad to Acro mode (not Angle or Horizon) and test again. If it still does weird stuff post a vid, too hard to guess from what you have said in the OP
ebchopra
