My setup
Raymon,
Just curious, why didn't you use the Betaflight F3 FC?
Well the main reason is, that i'm using the aikon electronics 4 in 1 esc with build in pdb. I don't have use for the pdb in the betaflight FC. If I would use the standard esc's the Betaflight FC would be my #1 choice. Last weekend I ordered the Omnibus F3 flightcontroller to test out! It's basically the the same as the betaflight fc but without the pdb
Do you always run zero expo? Your flights are so smooth, I thought for sure you had some expo in there.
I never use expo. Since BF3.0 betaflight the expo is set automatically. Adding extra expo will result in very strange flight behaviour... at least for me
blackphoenix
