New here from Seattle
Biker
Hi all,
I know there are some scratch build gurus in here and if you are one of them, perhaps you could possibly help this total noob out here, after all these years messing with fixed wing aircraft, I decided to try my luck at a scratch build drone in order to learn more about them, I've also been dabbling a bit with FPV and would be interested in any information I can get in terms of learning that as well, I'm not that great a flying them but do pretty well with fixed wing, even though drones fly almost the same direction-wise, I suppose it's the size and orientation that throws me off, I'm actually trying to learn to fly drones without the use of FPV for now, or is it better to use FPV glasses and learn that way?
In regard to the scratch build I mentioned, everything went ok until I reached the point of connecting a Rx (DS2500 Receiver, not sure of the brand) to an X-Racer F303 V3.1 Flight Controller, that is where I'm a bit confused. I've enclosed a few photos of the parts in question, I would appreciate very much if someone could shed some light on this, maybe "connect the dots" ?
Many thanks in advance
Biker
Hi all,
Biker
Welcome to the forum.
Sorry can't help, but enjoy when you're sorted. 👍🏻
Reactions: Biker
You will need to know the pinout diagram & the protocol for the DS2500 and most likely have to remove the servo pins unless they match the UART sequence & spacing on the Flight Controller (FC). Power goes to any 5v pad, & ground goes to any GND pad, One of other two "channels" has to be a UART RX which goes to a TX pad on the FC and the other one has to be an RX which goes to the TX pad on the FC. UARTs 1 & 2 are labeled thusly on your FC and either will do when that UART is selected appropriately in the Ports tab of the BetaFlight configurator and the correct protocol is entered on the receiver tab.
Hi Dan,
I was just thinking that the channels 1-4 were just the same as a normal Rx, here's some of the specs on it that I was able to track down.
Item Name: 2.4G mini receiver
Channel: 4CH
Weight: 2.2g
Resolution: 1024
PWM Output: Yes
Operating Voltage: 3.5-10V
Current: 50MA
Would it be better to just install a tiny Rx from say "HItec" or "Spektrum"??
Thanks Dan
~Biker
BetaFlight communicates with the Rx via any of the unused UART (Universal Asynchronous Receive Transmit) ports and I don't see any "first 4 inputs" on your F303. UART 1 & UART 2 are there & labeled on the right side and unless you can correctly identify the receive and transmit pads on the RX it unlikely to work correctly.
Mfett
