No Map on ipod-controller display F22 S3
boysentom
SJRC F22 S3 XR 4K Drone​
The Problem is that on the display of the remote control there is NO Google Maps visible! I so cannot use the GPS Points to fly to!! Controller connected Witz Home WiFi, all New Updates Drone, drone flies fine
In the Menu MY DRONE it says to create an Account. I Tried it with MY Google Account but it does Not Accept it, Network Error!ist the Registration of my drone in the Menü - my drone- Essential???
What shall i do? I have just i white map on the display without grafics just the actual gimbal View, no possibility of finding drone
Please Help me
Thank you
Thomas
Reactions: Maus
I have the same issue as well. Just bought the same type of drone like yours, already tried resetting it like a gazillion times and even downgrading the SJ F PRO ipad.apk to version 2.7.4, the same version that I saw reviewers used but still not working. I downloaded google maps on board to test if the hardware module is damaged, but it works...perfectly fine without lags or anything. My diagnosis is it's not the hardware nor the ipad apk that's broken, I think it's missing the google maps module somewhere. Problem is, I don't know where to get it. Maybe someone could help so I can fly this thing off the ground.Thank you.
Regards,
Maus
(Note: I did try switching wifi networks, satellite connection was way above 5 (the required satellite power needed to activate GPS), turned the bluetooth on, location services on, did left the drone AND the controller for 15 minutes outside but to no avail)
Probably a similar issue DJI had many years ago where their Goggle Maps API key expired, and it's not gonna work again until they release an updated app.
Update: The map works now I don't know how. I just updated it from version 2.7.4 to the latest 2.7.8, left it overnight without checking the map and then tried it today and the map worked, even without connecting the drone it still shows the map
LonaS324
