Noob!!!! Help!!!
Noah
So I purchased an Eachine Wizard X220 - flashed firmware on Betaflight... all things a go... Then when I activate motors and go to take off it gets about 6" off the ground and then all engines stop.... Falls to the ground... I can re-engage motors and same thing everytime... Please any ideas?
Could be a number of things, lets start with the basics. Do you have a multimeter to check if your battery is fully charged? It should be putting out 16.8 volts fully charged
Got it... I restored everything back to default on Betaflight and just made the few changes that I knew had to be adjusted... We are in the air thanks!!!
Reactions: Torc
az.lonewolf81
