Hi there,
I'm having a problem with my AIO FC+ESC board from Eachine Novice-II.
One of the motors spins like 30% slower than the other 3 motors.
I'm running bluejay bidirectional firmware on the ESC so I can also see the speed and it shows like 2400 rpm for the problematic motor and 3600 for the other 3 motors. At full power that ratio is 30k rpm versus 39k rpm.
The drone actually flies, because of the very function of the FC, which stabilizes the drone - in this case by slowing down the other 3 motors... so it flies, but lacks power...
I tried to exchange the motors and it appears that the motor connected to the motor 1 pins is always the slowest. I've never seen a half-dead FET, but you never know
It may be a bad FET, or a fet driver, or any other component... I don't know.
I connected the drone today to a betaflight, plugged in the battery (2s), enabled the motors, started the motors with the sliders at 1018 or something (the slowest possible).
Then I clamped my oscilloscope between a ground and the motor's wires.
What I found out is that on a good motor, all three wires show very similar signal to this:
And on the motor 1 two wires show very similar signal to the one above, while the third looks different... the spike is much higher ....
Does anyone understand what's going on there?
