- Joined
- Aug 19, 2019
- Messages
- 172
- Reaction score
- 147
- Age
- 46
Hello everyone,
I need your help with the Tryo129 Rssi. If you can see my circle in red and the arrow that is the pad I used to connect my s port wire. Right above is where I use the plug for Sbus, and power. I am using frsky XSR receiver works great however no RSSI. The pad right next to it is Tx2 , so I believe these two pads are uart 2? I just would like to know what in betaflight I have set in the ports tab\cli? I know this is an older receiver but it has good reviews and it works well. Just wanted to know if I am even in the right direction. I do read that the newer xm receivers can get telemetry through sbus however this receiver came with 5 wires, sbus, ppm, s port, power, ground. I have sbus, power and ground connected though the port, and s port soldered onto that rssi pad. Any suggestions would be great. Thanks.
