question about antennas on fatsharks
jlgaustin
So if I get RHCP clover antenna set, the patch antenna should also be the same polarization correct?
Can anyone recommend some decent antennas on fatsharks with a diversity module?
Yeah you always match polarization. Immersion RC and ready made RC make some good ones. You can actually use a LHCP patch antenna with a RHCP on the tx but you will not get nearly as much distance as matching them.
williamljackson
