Receiver suddenly isn't connecting to FC
mrmund
My qwad was working fine one day. The next day I went to fly and it starts up properly but it won't connect with the transmitter. The receiver lights up, is definitely bound but the FC doesn't seem to know its there. Looking in the goggles it's like the radio is turned off. I removed the XM+ receiver I was using and installed a new R-XSR I had, bound it up but still the same problem. Visual inspection shows nothing amiss. I'm stumped.
Zeus F722 FC
Tried both the original XM+ and the new R-XSR
Any suggestions?
Zeus F722 FC
Any suggestions?
Check your port assignments in Betaflight and make sure your receiver UART is still setup properly. Also check the configuration tab to ensure your receiver protocol is properly setup. It's possible your Betaflight config got messed up. It's not likely but also possible you have a failed UART on your FC.
adax
