SD Card question
tacoman
I just took delivery of an FVP and am doing the function checkout. It says that the SD card is missing. There is an SD in both the googles and the aircraft. Which one is it having a problem with?
I suspect one or both are incompatible. I have tried reseating both. They were both on the qualified list. I need to know which one is the problem.
Good idea. Is there a format function in the DJI system or can I just do it on a PC?
Worked. It took some exploring but I did find the sd card format function. I have quite a bit of time on a Mavic Pro. The FVP is just enough different so things are not where you expect. I will figure it out but kind of slowly.
Soso
