- Joined
- Apr 9, 2022
- Messages
- 1
- Reaction score
- 0
- Age
- 24
Sadly I cannot post videos, but I will attempt to describe my problem to the best of my ability. So when I am in betaflight, my modes and my channels show up and seem to work fine, the issue arises when they do not control the drone after it is unplugged from the computer. There are no arming flags, and nothing that the transmitter does does the drone do. There are no arming flags, and everything else seems to be fine seen as though everything seems fine in betaflight. Any help would be greatly appreciated.
Thanks,
Jack
UPDATE: After some screwing around in betaflight, when i unplugged by fc, the gyro light went from flashing blue to off, in which case the drone armed, I cannot, however, get the drone back to said state, I hope that this is at all helpful.
Problem solved, I have to turn the drone on with the arm switch turned to on, no other switch will work, but I can get it to arm when it is turned on from the start then by turning it off.
Thanks,
Jack
