- Joined
- Nov 16, 2023
- Messages
- 1
- Reaction score
- 0
- Age
- 28
Hi guys, am Ronnie, I'm new to fpv hobby - i build my first drone Speedybee master 5 V3 with Speedybee F7 V3 stack etc. i bought "Flywoo Goku M10 mini V3 gps" below mention is the problem am facing, please help me I'm very eager to fly this drone.
- All connections are wired correctly.
- At first i tried UBLOCK protocol with baud rate 115,200 and in the ports tab gps is set with baud rate 115,200. the gps symbol in betaflight didn't turned on (yellow gps symbol) Later i tried "NMEA" protocol with baud rate 115,200 and then the gps symbol turned on in betaflight. But i can see signal strength and sats number and latitude and longitude but i cannot see "GNNS id" or STATUS for the satellites I've waited for more than half n hour. The picture is below.
- This is what I'm seeing and unable to understand, Later i tried using "UCENTER 2" to check, this is what i found -
- "It is showing not receiving data" then i tried device configuration
It shows GNSS configuration could not be retrieved.
I'm stuck with from 4 days. Please me and find me a solution.
Thank you.
Thank you.
