Transmitter(Flysky I6) has no input
Mcknight
Hello everybody,
I am having an issue with a newly bought tinywhoop (eachine trashcan), the tinywhoop is PNP for sbus. So i also bought the Fs-a8s, i installed the receiver and binded the transmitter. All good till I connected it to betaflight. Betaflight does recognize the transmitter but has no input.
What I did so far:
- Changed the setup within betaflight to SBUS
- Tried all ports
- Updated the crazybeef4dx to the latest firmware.
Still not working
So for now I am running out of options
Could anyone help me?
Thanks!
Have you tried changing the receiver setting in Betaflight from sbus to ibus?
In the receiver menu of Betaflight, do any of the controls respond to the stick movements of the transmitter with battery connected? What procedure did you bind to the receiver with - using CLI or button method? Also, what version firmware is on the FC?
have you solved? i have the same problem too
Make sure you update the firmware to the FlySky version, not the FrSky version. Look at the file extension - should end in 'CRAZYBEEF4FL.hex
Also, I found it works only with version 4.0.0 and not any version higher.
