Tyro99 Flysky Setup
For iBus, you need to bridge the right and middle pad to enable iBus.
Yes! You already have your receiver plugged in to the correct port, by soldering those to pads together, it will tell your flight controller to output an iBus signal. If you soldered the centre and left pad it would output sBus signal. Easy peezy
