Weird Drone Behavior
otoe10
Ok, so i just finished building my 2nd drone. All soldering, connections, etc. seem fine. I take it out for the maiden, and it takes off just fine. However, it seems a little under powered. Soon, it drops out of the sky, an a few seconds later it does the "beep beep beep" aka the sound when u plug it in but not the last 2. I thought it could have been my old batteries, but they are all at correct voltage. However, they may not be outputting enough under load. Any suggestions or comments?
What exactly is the "correct voltage" they are reading? Let it fail, and then read the voltage across the outside 2 balance connector pins while it is still plugged in, nothing really pops out about your description except low voltage or bad connection.
Reactions: Keifie and Wayno52
viorel007
