4” Frankenstein
dr0nrb0nr
As I usually mention, I am fairly new to racing drones. My first 2 were RTF and cam early spring 2018. By August 2018 I did me first build and so far have built 5 from scratch.
Each time I do a build I implement something new I’ve learned and retrofit prior builds to match.
The quad below will be a culmination of everything I’ve learned so far. I’ve never used the stack or motor before. I’m conducting an experiment using 2207 2450kv and 4” props on 5s.
I watch a lot of YouTube reviews on cameras, flight controllers, esc, frames etc.. you name it, I watch it.
I typically dry fit the build before I solder anything.
Here is a part list for this build,
Proton 4” 293 grams w/ props
* Mamba F405 30x30 F4 stack w/ blheli_S 40amp esc
* Iflight Xing 2207 2450KV
Gemfan Flash 4052
* TBS Unify pro mounted on whitenoise Unify pro mounting board
* Realpit vtx switch
* Runcam Micro Swift 2
* Frsky R-XSR
* Luminier Axii Stubby
* Running Smart audio and Lua Scripts
I’m looking to record the build video and share
