Antenna replacement
Anzacjack
Just broke one of my stubby antennas. Dropped the goggles when passing over. Grrr
So
Whats good alternatives for a replacement. Are any of the aftermarket antennas better than standard as far as signal goes? Are the patch antennas built into the faceplate any good. Im only using these with the dji fpv drone. Happy to just replace the standard antenna, but if im buying, i may as well improve if i can.
also the signal seemed to be unaffected with one stub broken (top left hand stub from pilots perspective). I thought i read somewhere that one of them was not used?
cheers
The V2 goggles are dual-band. How badly did you break it? I broke one of mine and the only damage was to the outer plastic casing. I was able to superglue the plastic back together and put it back over the antenna. Works exactly the same.
AFAIK the only place to purchase the dual-band antennas are through DJI directly
IolaLuther
