Battery giving power to fc but the ESCs don't beep
jsa29
Hi there,
Motors are hooked up to the ESC. When i disconnect the flight controller, still no startup tones from ESC/motors by its self.
Attaching the FC, same issue but FC is powered up and manageable from BetaFlight.
I always use Smoke Stopper and never started without one since starting the build.
I were able to have the startup tones first two times i powered up the ESC alone, then nothing.
There is nothing soldered on the FC for now.
ESC is : YSIDO BLS-60A ESC
Thanks for you help !
Jossey
