Binding DSMX Receiver with Flip32 F4 and DXE [SOLVED]
BillDebevc
Las Vegas
Website
bimthoughts.com
Hello,
I am having a little issue binding my receiver to the transmitter. I am able to bind it at the Local Hobby Shop using their stuff, but not with my stuff. That is if they connect my receiver to their big controller with a bunch of plugs and using a bind plug it binds just fine. So I know it binds, It just won't bind using the Flip32 F4 controller.
I have searched the web and youtube to find a solution, but I have not found one that works.
I have tried using "set spektrum_sat_bind=9" and "set spektrum_sat_bind=8" in the CLI in Betaflight. I have also tried using the button on the receiver. When using the button I get the flashing light on the receiver, but it fails to bind when I hit the bind button, I then get the "I don't like you" beep on the transmitter.
Attached are images of the Receiver and Flight controller, the transmitter is a DXE and has the CleanFlight programming with 9 channels selected. I am also running the latest firmware on the F4 and transmitter.
Sorry i can't help, not sure about that one. I have done the "run to the hobby shop" deal....lol. Was embarrassing, they had it bound in 5 secs, lol, i couldnt get it to bind to save my life. They got it to bind the same way i tried, said it happens all the time...lol
Are you putting a few feet of space between the transmitter and receiver? Sometimes it won't work if they are too close to each other.
Also, if it worked with a binding plug at the shop, can you try a binding plug at home?
